How to print a cube with no walls?
Omni
 Omni
(@omni)
Good day!
I am looking to print a large object to be assembled from multiple large prints. I would like to not waste filament on the sides that will be glued together. Is there a way to remove walls in the slicing process?
Thanks!
- If it wasn't clear what I am trying to do.. Can I print a cube where only the top and bottom of the cube have solid walls? If looking at the side of the cube you would see in the infill pattern.
Publié : 22/07/2019 12:30 am
toaf
 toaf
(@toaf)
RE: How to print a cube with no walls?
put vertical shells to 0
I don't think its worth it. just print a cube
Ce message a été modifié il y a 7 years par toaf
Publié : 22/07/2019 2:20 am
Omni
 Omni
(@omni)
Thanks for the reply!
Your answer makes total sense for my example, however I shouldn't have been so general. In my case I'm looking to make say 1 or 2 of the cubes walls have no shell. Is there a way to pick or select sides that are flat and indicate that those should not have a shell?
For this print I'm looking at 25 - 30 almost full platform builds which will then be glued together, not printing the shells on sides that will be glued together will greatly reduce the material needed 😉
Publié : 22/07/2019 2:31 am
chris.p8
(@chris-p8)
How about using a modifier? If you check the blog there is an article about using mesh modifiers, you could create your cube and add a modifier
to the top that had the top and bottom shells set at 0?
If you are not sure send me a PM and I'll have a go at creating an example for you?
Regards
Chris
Publié : 29/07/2019 10:30 am
