G-Code not same?
ronyd
(@ronyd)
G-Code not same?
Originally was usig a 6mm nozzle.  I replaced the pre-assembled hot-end with a 4 mm nozzle yesterday.
I created another G_Code on the model and have selected 4mm nozzle.  When ready to print, msg indicates G-Code is different from printer.
Do I need to go into a setting on the printer to tell it is a 4mm nozzle?
I went ahead with the print just to see how it goes anyway.
Opublikowany : 08/01/2023 6:03 pm
ronyd
(@ronyd)
RE: G-Code not same?
I check settings and yes, had to set printer to 4mm.
Opublikowany : 08/01/2023 6:24 pm
