Difference in 2.5 rambo base stl model vs code model
I noticed when I printed out the PRUSA G-code file for the MK 2.5 Rambo parts that the base had an R2 embedded in the plastic. Because I was having trouble with the PET filament I ended printing from the downloaded PRUSA STL file which produced a Rambo case which has an R1 embossed on the case. On inspection I noticed that there is a difference between the R1 base and the R2 base around the cable entry areas. Does someone have the STL file for the R2 version of the MK2.5 Rambo Base? Even better it would be nice of the STL file contents matched the code file contents on the PRUSA support page. Thanks, Jim
Postato : 17/07/2018 3:35 am
Re: Difference in 2.5 rambo base stl model vs code model
I checked in the common place. Github MK2.5 Parts
This is the one I saw out there.
No sign of R2.
MK2S kit owner since 8/15/2017
Postato : 18/07/2018 10:07 am
