confused on Enabling Supports for this model?
ronyd
(@ronyd)
Not sure what support settings are needed for the attached model?
thankx
This topic was modified 3 years temu 2 times by ronyd
Opublikowany : 10/08/2023 1:26 am
ronyd
(@ronyd)
RE: confused on Enabling Supports for this model?
Hmm why is my gcode file not uploading? it's only 2MB...
Opublikowany : 10/08/2023 1:35 am
Don't bother with gcode, it's no use to us.  Instead send a .3mf file:
Files > Save Project as
Opublikowany : 10/08/2023 2:32 am
ronyd
(@ronyd)
Hi yeah also tried the .3mf file last night.  Just does not upload?
Opublikowany : 10/08/2023 11:22 am
ronyd
(@ronyd)
sorry for delays.  Looks like had to zip the file.
thankx
This post was modified 3 years temu by ronyd
Opublikowany : 10/08/2023 11:46 am
ronyd
(@ronyd)
thankx sorry for delay
Posted by: @diem
Opublikowany : 10/08/2023 11:49 am
ronyd
(@ronyd)
looks like the file must be a zip file to upload.
Posted by: @ronyd
Opublikowany : 10/08/2023 11:51 am
René
(@rene-3)
Place the object on plate as follows, then you don't need support.
Opublikowany : 10/08/2023 1:25 pm
ronyd
(@ronyd)
aah ok thankx... so even though slicer places the object in a default position doesn't mean you should not change that position to accommodate support... thankx
Posted by: @rene-3
Opublikowany : 10/08/2023 1:37 pm
ronyd
(@ronyd)
interesting when slicing in that orientation still shows message saying
Posted by: @ronyd
Posted by: @rene-3
Opublikowany : 10/08/2023 1:58 pm
René
(@rene-3)
Ok my mistake.
Didn't see that the three intermediate pieces ran to the bottom.
But no problem then you put the object down on the bed as follows.
Opublikowany : 10/08/2023 2:22 pm
ronyd
(@ronyd)
Do i ignore to enable supports: everywhere, build plate only, or enforcers only?
Posted by: @rene-3
Ok my mistake.
Opublikowany : 10/08/2023 7:50 pm
René
(@rene-3)
Forget my previous answer, place the object as previously indicated.
Use the default (unmodified settings) 0.20mm layer height. You don't need any support!
Opublikowany : 11/08/2023 5:04 am
ronyd
(@ronyd)
Aah ok  … make sense thankx again
Posted by: @rene-3
Opublikowany : 11/08/2023 11:42 am
I agree with  @ronyd's final orientation & no support.  0.2mm layers will be suitable.
This part is not well designed for 3D printing, the narrow gaps make support difficult and hard to remove and the tastefully rounded corners are both too small to support and overhang too much for clean printing - but it should print a useable part.
Opublikowany : 11/08/2023 12:57 pm
1 ludzie polubili
jseyfert3
(@jseyfert3)
For a little more detail: PrusaSlicer puts the object onto the bed in the same orientation as it was in whatever CAD software was used to make it. Some people consider this when designing their parts, some do not.
When I design my own parts, I ensure that in CAD the part I want to be on the printbed is sitting on the XY plane, and the rest of the part extends up the positive Z-axis. When exporting as STL and loaded in PrusaSlicer, it'll be in the orientation I want it to print already. And my personal goal while designing parts for FDM printing is to design them such that supports are not required.
Posted by: @ronyd
Posted by: @rene-3
Opublikowany : 11/08/2023 1:09 pm
ronyd
(@ronyd)
Thankx for that important tip.  Always wondered if  the object is placed  as a default for the slicer.
Posted by: @jseyfert3
Posted by: @ronyd
Posted by: @rene-3
Opublikowany : 11/08/2023 1:42 pm
