Can't print TPU (60A)
Antonio Marmolejo
(@antonio-marmolejo)
Mitglied
Hi everyone,
I'm trying to print some TPU (Filaflex 60A Pro White) on my MK2.5S (last firmware to date) with a 0.4mm nozzle.
I can't manage to print anything, the filament does not extrude. I gets tangled in the idler and wraps the gears.
Event if I try to push it manually down to the nozzle, it ultimately gets stuck in the idler.
I've tried multiple temps (215, 230 and 270) and multiple tensions in the idler:
 - loose, almosst holding the screw
- average, PLA like
- hight tension, stongly screwed.
If' cleaned the nozze by doing a cold pull.
Can anyone help me? Thanks
Veröffentlicht : 17/11/2023 5:07 pm
3Delight
(@3delight)
Moderator Moderator
RE: Can't print TPU (60A)
I don't any experience with TPU, but have you tried slowing the print right down? Combining this with loosening the idler a little would make sense to me from a physics/mechanics point of view...
Veröffentlicht : 17/11/2023 5:25 pm
Antonio Marmolejo
Mitglied
Thanks for your answer.
I've slown down the print speed to 40mm/s.
When trying to extrude the TPU, I'm using the knob (Parameters > Move axis > Extruder) to do it slowly.
Veröffentlicht : 17/11/2023 5:39 pm
3Delight
(@3delight)
Moderator Moderator
Hope it helps!
Veröffentlicht : 17/11/2023 6:34 pm
Antonio Marmolejo
Mitglied
Non, it did not help.  This was my workflow before my initial post.
Veröffentlicht : 17/11/2023 6:57 pm
