Can you print Taulman 910 on the powder coated sheet
KLAUS
(@klaus-3)
Was wondering If it is possible to print Taulman alloy 910 nylon on the Prusa powder coated sheet?
Has any one had success with this? What type of glue did you use on the bed?
Thanks
Napsal : 01/02/2019 9:57 pm
Slavkosky
(@slavkosky)
RE: Can you print Taulman 910 on the powder coated sheet
Bringing this post back from the dead. I'm wondering the same thing!
i3 MK3S+
(stock)
- Powder-coated, Satin, & Garolite Sheets
- 0.25/0.4/0.5/0.6/0.8mm NozzleX
- 0.6mm Bondtech CHT
_____SL1S & CW1S (stock)
Napsal : 06/04/2021 10:36 am
FWIW - I was able to print Taulman Bridge on the smooth PEI sheet by applying a coat of glue stick. I used the glue stick Prusa provided with the Mk3 printer.
Napsal : 06/04/2021 2:56 pm
egar
 egar
(@egar)
@slavkosky
Take a look at Prusa's material guide page -- https://help.prusa3d.com/en/materials
There's a section on nylon.  I can't speak from experience, so take this for what it's worth
Napsal : 06/04/2021 4:30 pm
@bobstro
Same here.  I have not tried on the textured sheet.
Napsal : 07/04/2021 12:59 am
Slavkosky
(@slavkosky)
Hmm, ok thanks for the insight! I'll be trying it soon after I dry my spool of Black Alloy 910. I'll try with/without glue stick and report back
i3 MK3S+
(stock)
Napsal : 07/04/2021 3:18 am
Slavkosky
(@slavkosky)
Seems that the textured sheet worked great after dialing in Live Z Calibration and adding a bit of glue stick. I was initially too close to the bed and ended up with the first layer supports all over my nozzle instantly jamming it, but once I backed off a bit the 910 laid-down beautifully! I haven't tried a bigger part, I was just printing a small gear (I plan on building the V2 Lack enclosure before printing larger with this stuff)
Z+ face (with top face ironing):
Z- face (no raft)
Tooth detail:
This thing is hard as a rock. Alloy 910 very impressive stuff!
i3 MK3S+
(stock)
Napsal : 14/04/2021 2:18 am
ffdez
(@ffdez)
Hi. Try Garolite. I use it with success (no glue or anything over the bed) with eSun PAHT-CF.
Napsal : 31/08/2021 6:17 pm
