Y axis making grinding noise when all the way back
delaney.a
(@delaney-a)
My filament spool fell and broke my Y axis motor mount. I put on a replacement now the Y axis grinds when all the way back. If I bump the table it will stop.
I have made sure that the distance on the back 2 screw rods are correct. I did not change the 2 long screws.
When I disassembled the back to take off the Y motor and motor mount, I un-did the 4 nuts on each end and the 2 larger nutson the end, then undid the nuts that held the printed legs and mounts, then the ones holding the mount
When I re-assembled everything I made sure the calipers were set to 65 on the left side and 77 on the right side. The front to back nuts did not change any.
Any ideas?
Veröffentlicht : 28/06/2018 5:53 pm
