Y-Axis belt tightener for the MK2.5
Chris
(@chris-4)
I had a loose Y-Axis belt, and tried to tighten it. I was having trouble, and since I also have a MK3S I realized that it had a superior way to hold the belts and tighten them. I printed the two pieces, put them on my MK2.5 and Oops. The pieces are not tall enough to hit the mechanical stop that the Y-Axis has on the MK2.5.
So, has anyone printed a different piece that it tall enough to hit the switch? Should I try to move the stop a bit higher - closer to the heatbed frame - so that the part might hit it?
Posted : 01/09/2020 1:41 am
Clemens M.
(@clemens-m)
RE: Y-Axis belt tightener for the MK2.5
I modified my MK2.5 in that way that I built a solution similar to the Prusa Mini (see below)
Best regards, Clemens
Spanner_Y-Achse
Posted : 01/09/2020 8:27 am
Clemens M.
(@clemens-m)
I printed the parts in PETG with 3 perimeters and 40% Infill,
Posted : 01/09/2020 8:28 am
Chris
(@chris-4)
Ooooh. So you left the original piece, and made the end adjustable. That's not a bad idea. I will see if I can get the old piece with my shortened belt back together. Thanks.
Posted : 01/09/2020 4:07 pm
