X-carriage can't trigger x-endstop after upgrade
Hi
Just upgraded from MK2S to MK2.5. Update and self-test went smooth. However since then I've noticed that the printer sometimes is having a hard time triggering the x-axis-endstop. There is no obstacle that is preventing it from reaching the endstop and I can physically pull the x-carriage to trigger it. I it does seems like it gets a bit harder towards the endstop though.
Could i possibly be the belt that is too tight? Any other suggestions?
Publié : 01/12/2018 9:17 pm
Re: X-carriage can't trigger x-endstop after upgrade
I had the exact same issue. Make sure that the fan and extruder wires are nicely tucked away. If they stick out a little it prevents the carriage to hit the endstop. After I rearranged the wires the endstop works perfectly.
Publié : 27/12/2018 7:21 pm
