X-axis drooping
Themaninthesuitcase
(@themaninthesuitcase)
X-axis drooping
I recently rebuilt my 2.5s after a hotend leak wrote off the hotend.  I used all new 3D printed parts for the X-axis and extruder assembly. Fit was good on these, snug but not impossible.  I did ream the 8mm rod holes with a drill bit to get them to fit. I also used new bearings on the Z rails.
After the rebuild when I power off the printer the X stepper motor side of the axis drops around 2mm.  It remains stable whilst power is applied to the steppers.
I did used to have the Z drive rods lubricated but I read that was a bad idea and so have cleaned off the lubricant now.  Could it be this has worn the captive nut enough that there is no longer enough friction to hold position under the weight of the motor?
I also checked the X axis length, which is 307mm between the orange printed parts.  I believe this to be the correct value reading the comments in the build docs to give the correct spacing.  So I don't feel that it's the axis is too long and pushing it out of alignment.
This was originally a Mk2 from when they first launched so parts are starting to get quite old now so wear seems like a reasonable explanation.
I don't have a photo handy but this show what's happening using the prusa stock photo.
Any help would be appreciated as it's tiresome having to redo the level each time by maxing the Z travel.
Opublikowany : 12/11/2021 9:58 am
Chicago Keri
(@chicago-keri)
Sounds like you're on the right track.... it sounds like the Z axis has too little friction, which is odd.
The linear rods and bearings are supposed to have low friction, so I would leave them alone.  The Z-axis screws should be about centered at the top Z mounts which is set by the setscrews on the Right X-axis supports, along with the X belt tension, to some degree.
I would try the least expensive thing first, the POM nuts at the top of the X supports.
You didn't do anything to substantially increase the weight of the X axis, did you?  Like a giant X or Extruder stepper motor(s) or 100% infill on parts?
Good Luck!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Opublikowany : 13/11/2021 10:36 pm
