Where can i get a MK2.5S replacement print fan?
Can anyone give me any tips where i could get a MK2.5S replacement print fan?
Unfortunately it's not available anymore in the Prusa Store. 🙁
Is it a Sunon MF50151V1-A99? (I didn't have time to disassemble my extruder yet to look if there is a sticker or anything.)
Opublikowany : 12/05/2022 12:30 pm
RE: Where can i get a MK2.5S replacement print fan?
Amazon (if you're in the States) is usually a good source for the various small fans, but I just did a check on that number and came up empty.
Opublikowany : 12/05/2022 10:17 pm
Topic starter
answered:
https://eu.mouser.com/ProductDetail/Sunon/MF50151V1-B00U-A99?qs=EU6FO9ffTwdTtwaYBW8Pig%3D%3D
It seems to be exactly the same with those specs:
Input: 12V
Max RPM: 5000
Airflow: 4.5 CFM
2 wires (pins)
I also found it on Amazon.
Opublikowany : 16/05/2022 8:49 am
