Unload Doesn't Unload Enough
Engineer Keith
(@engineer-keith)
I have a mk2.5s with a bondtech hot end.
When I use the unload feature (while at the right temperature) the gears back the filament out but not enough.
I have to run it twice to be able to pull it out. It's just barely not enough.
How do I adjust the firmware to back the filament out just a little more?
I have the latest firmware from bondtech and this issue have persisted across all firmwares. I can't remember if I had the same issue before installing the bondtech.
Opublikowany : 26/12/2020 4:08 am
