Question regarding conditional gcoding with Slic3r PE
DerBierBaon
(@derbierbaon)
Hi guys,
I've hit a little bump regarding information I can find about the usable parameters with the conditional gcode. I wanted to add a "if"-statement to my end gcode which should read out the current z-height after the print and if it's below 50mm it should movethe extruder up to z=50mm and if it's above it should ignore it.
My idea was: {if layer_z < 50} G1 Z50
But I only found input on the non-PE Slic3r and there it was mentioned that the layer_z parameter was only available in the before/after layer change gcode.
Any infos on where I can read up on this or maybe a solution?
Help would be greatly appreciated 🙂
Regards
-DerBierBaron
Postato : 04/06/2018 7:41 pm
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Re: Question regarding conditional gcoding with Slic3r PE
https://github.com/prusa3d/Slic3r/wiki/Slic3r-Prusa-Edition-Macro-Language
Postato : 04/06/2018 8:03 pm
DerBierBaon
(@derbierbaon)
Thanks for the reply.
But that seems to be a problem though: On that page under "scalar variables" it says:
layer_z (only available in layer change GCode)
layer_num (only available in layer change GCode)
I don't have any idea how to implement my idea to the layer change gcode instead of the end gcode. If I just put my statement from my first post there every program will stop after the first layer...
Any ideas how it could still be implemented? maybe with "==" and another statement?
Regards,
-DerBierBaron
Postato : 05/06/2018 5:06 pm
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Sorry, but I don't understand what you want to achieve.
it should be
{if layer_z < 50} G1 Z50 {endif}
It should work in the layer change G-code, but I don't understand what you want to achieve. Such a G-code will break your print.
Postato : 05/06/2018 8:04 pm
richard.l
(@richard-l)
Utenti Moderator
it should be
I believe he is wanting to place this in the End G-Code script so that if the finished print is less than 50mm high it will raise the z-axis to 50mm when complete. I think a better solution is what I have in my end g-code ...
G91 ; Use relative coordinates
G1 Z10.0 F5000 ; Lift Nozzle by 10.0mm
G90 ; Use Absolute Coordinates
G1 X0 Y200; move bed to front and home x
M84 ; disable motors
Postato : 06/06/2018 4:06 pm
DerBierBaon
(@derbierbaon)
Hi there,
yes richard.l is right. What I'd like to make is that the extruder should lift itself up to at least 50mm after the print, which is not possible with the {if....}-code I posted earlier. I want this due to the troubles I am having with the mesh bed leveling and a heated up PINDA 2 probe. Usually I do this after every print now, i.e. I manually lift the extruder with the move axis function in the menu. The reason I am doing that is to let the PINDA cool off more easily in between prints, so that it can't be kept warm by the heatbed.
Therefore the code I posted will not work (which is what I wrote earlier) and I now would like to find a way to do this nontheless.
richard.l your solution is one way to work around my problem. I could lift off 50mm instead of your 10mm. But wouldn't this push the x-carriage against the top guide braces on the frame for pieces at that height? Similar to what is done for z-calibration?
Regards,
-DerBierBaron
Postato : 06/06/2018 6:29 pm
richard.l
(@richard-l)
Utenti Moderator
I don't think so because the firmware is limiting the z-axis height to I believe 210. Once there it stops. I haven't tried it but I can this evening when I get off work.
Postato : 06/06/2018 8:17 pm
