MMU2S Disassembly Instructions?
PieSupplies
(@piesupplies)
I've decided to throw in the towel and give up on the MMU2S. It's taking too much time messing with the filament detection, fixing failed loads, etc.
It's an expensive lesson to learn, and I hope it becomes reliable in the future, but it's not there for me yet.
What I want to do is to convert my MK3S with the MMU2S, to just a MK3S. The main thing I'm concerned about is how to swap to the metal ball based filament sensor from the IR one used by the MMU2S. Is there a conversion guide out there? I'm also not sure what parts I'm missing?
Any help would be appreciated, thanks.
Postato : 23/12/2019 5:19 pm
Mav63
(@mav63)
RE: MMU2S Disassembly Instructions?
Hi Alex,
I finally recognized that you got no answer / help / instructions / etc. to your post... unfortunately!
Really BAD behavior from Prusa!!
Since I am in the same situation as you, hoped there is a guide to bring the printer back to a normal MK3s.
Have you finally made it?
Appreciate your help here!
Thanks a lot!
Postato : 24/04/2020 10:17 am
Voidrunner
(@voidrunner)
Utenti
Hello
I see both of you have the same issue as me, and still, in 2023, I have problems, have either one of you found a solution or is the process still undocumented?
Thank you in advance
//Voidrunner
Questo post è stato modificato 3 years fa da Voidrunner
Postato : 13/08/2023 12:15 pm
