Mintemp error, but can print after warming up
christopher.a2
(@christopher-a2)
Hello there!
I have this weird, annoying problem with my 2.5s printer, it does not hinder me from printing, but I would still like to resolve it and came here for your help, if you are willing.
I went though a turbulent phase in my life and my printer ended up stored and unused for years, so a couple of days ago, I took it out of the moth balls and started printing again. I dusted the printer, lubricated the rods, a firmware update/calibration and here comes the gcode!
My first print failed and it turned out that the gear that fastens on the extruder motor was loose, so I tighten it and problem solved, ah the dopamine from solving the first printing problem after years was sweet. The printer finished its first print after its long rest in limbo!
Now to the issue at hand, since then, each time I print or try to load/unload filament, I get the mintemp bed error (around 30-31C), but if I power cycle/restart the printer and try again (while the bed is still warm from the first try) it does successfully finish the print. If I let the bed cool down  (around 18-20C bed temp) and retry I get the mintemp error again. Attached are images before (idle printer) and after (the moment the mintemp error appeared).
Thank you for your time, Christopher.
Some facts:
The printer was unused for years
The room temp is 17-18C
Napsal : 23/02/2026 3:19 pm
