Heated bed problem - change the MOSFET?
marco
(@marco-4)
In my mk2.5, The heated bed sometimes stops working:
  • I checked the tension from the power input and is OK.
  • The 15 Fuse seems OK (tested with multimeter => no resistance)
  • The onboard connector (Board -> heated bed) is OK. Just o be sure I replaced it and nothing changed.
  • On the on board connector, the tension is very weak (around 2V)
  • What I have to chek yet is:
  • Power Input -> Board connector (but visually it seems OK, no plastic melt, etc)
  • The MOSFET
  • My suspects now are on the MOSFET, it's possible to replace it? If so, how?
    Publié : 27/09/2018 10:38 am
    marco
    (@marco-4)
    Re: Heated bed problem - change the MOSFET?
    Nevermind.
    It was the Power Input -> Board connector.
    Changed it and now it's all OK.
    Publié : 29/09/2018 9:30 am
