Firmware Reprap or Marlin?
Ian
 Ian
(@ian-3)
Is the Prusa firmware mostly Marlin, or mostly RepRap?
I had thought it was Marlin, but having recently upgraded my Mk2 to Mk2.5 and brought all the software up to date, I note that Slic3r with the Prusa settings from GitHub is set to 'G-code flavor' "RepRap/Sprinter", and "Marlin" is a different option.
Having checked directly on GitHub, I think reprap is the right setting (that's what is in the .ini there), but I'm curious why.
Publié : 27/05/2018 10:10 am
Colin
(@colin-4)
Re: Firmware Reprap or Marlin?
In 1.39.2, the default is Marlin.
Publié : 27/05/2018 3:38 pm
Ian
 Ian
(@ian-3)
Yes, that's what I'd expect (given that I think the firmware is Marlin-based), but it's not what's in the Prusa settings now distributed https://github.com/prusa3d/Slic3r-settings/blob/master/old/Slic3r%20settings%20MK2S%20MK2MM%20and%20MK3/printer/Original%20Prusa%20i3%20MK2.ini line 9 says reprap:
# generated by Slic3r Prusa Edition 1.38.4 on 2017-12-19 at 15:32:13
gcode_flavor = reprap
That should be 'marlin' in the .ini file to get the Marlin option selected in the gui.
Publié : 27/05/2018 9:01 pm
Colin
(@colin-4)
Good question. The latest bundled .ini is Marlin. Either they're changing the recommendation, or there's something funny with that .ini since it hasn't been released yet.
Publié : 27/05/2018 9:24 pm
SGR
 SGR
(@sgr)
Hello
Until now I printetwith marlin and it worked well. but out of curiosity started to check what kind of g-code flavor I should use, but until now I donät find an answer.
Publié : 28/05/2018 6:50 pm
Ian
 Ian
(@ian-3)
OK, I don't think it matters.
I've generated gcode for a couple of models, and the actual tool instructions are identical whether I set Slic3r to Marlin or to Reprap/Sprinter.
I do get an odd difference in the duration prediction. For example, for one of the test cases the only differences in the file (apart from line 1 with a different timestamp) are:
56227 ; filament used = 10339.9mm (24.9cm3)
56228 ; filament used = 31.6
56229 ; filament cost = 126.2
56230 ; total filament cost = 126.2
56231 ; estimated printing time = 2h 36m 24s
56271 ; gcode_flavor = marlin
c.f.
56231 ; estimated printing time = 13h 52m 21s
56271 ; gcode_flavor = reprap
So the gcode is byte-for-byte identical, the filament consumption is identical (as you'd expect), but one is predicting 156 minutes and one is predicting 832 minutes ! (it's actually about a three hour print, I think). If set to reprap, Slic3r consistently reports a print time that's five to six times what it predicts for marlin. For a model that's actually a twelve hour print, the reprap option is predicting three days!
Publié : 30/05/2018 1:54 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
The reason for splitting the firmware flavor is described in the release log
https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.1-alpha
It really just influences the time estimator.
Publié : 04/06/2018 8:11 pm
