Does G80 save to EEPROM?
Grooperdude
(@grooperdude)
I sincerely appreciate yall taking time out of your day to answer my questions.
My google-foo has failed me.
1.  So right now i run 7x7 mesh bedleveling before every print. It works great.  But..I would like to only run 7×7 mesh bedlevel command one time and hopefully save those values to eeprom. That way I do not have to make a new mesh everytime I start a new print.
How can I save/apply the original mesh values to subsequent prints on my mk2.5?
(Same as above just worded differently) Is it possible to save and use the original mesh values i get from my 1st run so i do not have to run G80 before every print?
Last: If I remove G80 from prusa slicer... are the values from my original mesh saved to eeprom and used on every print? Or will the printer act like a mesh was never run.
If so, what can ido to make my mk2.5 save my mesh values until I need to run a new one?
The only time I would want to run mesh bedleveling again is if I swap filaments or use different bed temperatures.
I was thinking of running G80 the use M500 after it's complete to solve the problem. But I know there's been some issues with saving info to eeprom. We either use m500 or m503. Also, I don't know if the printer would automatically apply the previously saved mesh values when starting a new print.
Publié : 08/08/2022 2:22 pm
