Can't update firmware - ser_send(): size/send mismatch
gronk33
(@gronk33)
Hi there,
I'm on Windows 10. My MK2.5s is connected to my PC via USB on COM3 and I can see it listed in my device manager.
I've updated Prusa Slicr to 2.2. However whenever I try to flash the printer with 3.9.1 I get a host of errors (shown below).
I've never run into this issue before. I'm not running any other programs when I try to update.
Does anyone have any advice?
Thank you,
Ted
ERROR MESSAGE:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM3 -b 115200 -D -U flash:w:0:C:\Users\tcp\Downloads\prusa3d_fw_3_9_1_MK25S\prusa3d_fw_MK25S_3_9_1_3518_RAMBo13a_en-de.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 21 2020 at 12:45:57
                Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : COM3
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
avrdude-slic3r: ser_send(): size/send mismatch
avrdude-slic3r: stk500v2_send(): failed to send command to serial port
avrdude-slic3r: stk500v2_getsync(): can't communicate with device
avrdude-slic3r: Could not open port: COM3
avrdude-slic3r done.  Thank you.
Publié : 17/12/2020 10:01 pm
RE: Can't update firmware - ser_send(): size/send mismatch
Posted by: @gronk33
Hi there,
Thank you,
Ted
ERROR MESSAGE:
                Using Port                    : COM3
Hello and welcome to the Prusaforum!
Possibly something else is accessing the usb port. I would disable bluetooth or similar, maybe change the com port and start the slicer as admin.
Publié : 18/12/2020 3:04 pm
gronk33
(@gronk33)
@karl-herbert
Great advice - turning off bluetooth solved the problem. Thank you so much!
Publié : 19/12/2020 5:08 pm
1 personnes ont aimé
@gronk33
Thanks for the feedback! If only it was always that easy 👍
happy printing!
Publié : 19/12/2020 5:24 pm
FEST
 FEST
(@fest)
@gronk33
Hello. I had the same issue here and fixed it by turning off bluetooth during the flash. This info should be added in the pdf doc with the firware update procecure I think...
Publié : 14/03/2021 6:40 pm
