unexpectedly filmament change request
michael.r
(@michael-r)
randomly my printer requests a filemant change... every third print, sometimes more then one change request per object...
upgraded to 2.5s
Postato : 07/04/2020 7:20 pm
Area51
(@area51)
Utenti
RE: unexpectedly filmament change request
Try to turning off the filament sensor in firmware.
I had this problem and found out it was false filament run out and turning off the filament sensor fixed the problem.
Postato : 07/04/2020 11:12 pm
Posted by: @michael-r
upgraded to 2.5s
Would you give us more detailed information? Which sensor did you use (IR-sensor?)? Has it been adjusted correctly? Which slicer software do you use. Do you start the print from SD card or via octoprint or similar?
Postato : 08/04/2020 12:38 am
michael.r
(@michael-r)
@karl-herbert
print from SD - Card...  sensor is the latest version (mk3s) slicr is latest from Prusa
Postato : 09/04/2020 11:18 pm
@michael-r
Maybe you can find here your solution: https://help.prusa3d.com/en/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112226
or here: https://help.prusa3d.com/en/article/ir-filament-sensor-mk2-5s-mk3s_112214
Postato : 10/04/2020 12:09 am
