unexpectedly filmament change request
randomly my printer requests a filemant change... every third print, sometimes more then one change request per object...
upgraded to 2.5s
RE: unexpectedly filmament change request
Try to turning off the filament sensor in firmware.
I had this problem and found out it was false filament run out and turning off the filament sensor fixed the problem.
upgraded to 2.5s
Would you give us more detailed information? Which sensor did you use (IR-sensor?)? Has it been adjusted correctly? Which slicer software do you use. Do you start the print from SD card or via octoprint or similar?
@karl-herbert
print from SD - Card... sensor is the latest version (mk3s) slicr is latest from Prusa
@michael-r
Maybe you can find here your solution: https://help.prusa3d.com/en/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112226
or here: https://help.prusa3d.com/en/article/ir-filament-sensor-mk2-5s-mk3s_112214
