Pre print parts for upgrade from mk2s to mk2.5s
Hello,
I want to know if there a problem to print all the parts needed to the upgrade with black eSUN PETG instead of the included filament.
What layer height should I use? 0.2?
I'm asking this questions becouse I want to see that I can handle with printing those parts before I'm ordering.
RE: Pre print parts for upgrade from mk2s to mk2.5s
Yes 0.2mm and your Esun PETG should be fine.
I would recommend to print the MK2.5S parts from Nathan Whitchurch (Butterworth design) from my mini factory so your filament path is aligned correctly.
Why? Prusa files are not good?
this is the files right? https://www.myminifactory.com/object/3d-print-butterworth-design-prusa-mk3-mk3s-r4-extruder-mod-filament-path-alignment-and-indirect-mk3-filament-sensor-86329
@ido-s
I downloaded them about a month ago and the filament path was not aligned properly so started to model up a replacement. I then thought i better check that no one else had already done it and found these on My Mini Factory.
When you download them you will have a lot of files. You will need to check it is the correct version but i think it was the n4a-mk3s-plate-v1a that i printed.
i checked the files that prusa give you, on the parts i can see R5
so i guess they fix it
It's possible they have updated them now. I can't remember but i don't think R5 was there when i downloaded.
