Pre print parts for upgrade from mk2s to mk2.5s
sapancool
(@sapancool)
Hello,
I want to know if there a problem to print all the parts needed to the upgrade with black eSUN PETG instead of the included filament.
What layer height should I use? 0.2?
I'm asking this questions becouse I want to see that I can handle with printing those parts before I'm ordering.
Opublikowany : 07/05/2020 12:21 pm
lee.g
(@lee-g)
RE: Pre print parts for upgrade from mk2s to mk2.5s
Yes 0.2mm and your Esun PETG should be fine.
I would recommend to print the MK2.5S parts from Nathan Whitchurch (Butterworth design) from my mini factory so your filament path is aligned correctly.
Opublikowany : 07/05/2020 3:11 pm
sapancool
(@sapancool)
Why? Prusa files are not good?
this is the files right? https://www.myminifactory.com/object/3d-print-butterworth-design-prusa-mk3-mk3s-r4-extruder-mod-filament-path-alignment-and-indirect-mk3-filament-sensor-86329
Opublikowany : 07/05/2020 3:31 pm
lee.g
(@lee-g)
@ido-s
I downloaded them about a month ago and the filament path was not aligned properly so started to model up a replacement.  I then thought i better check that no one else had already done it and found these on My Mini Factory.
When you download them you will have a lot of files.  You will need to check it is the correct version but i think it was the n4a-mk3s-plate-v1a that i printed.
Opublikowany : 07/05/2020 4:38 pm
sapancool
(@sapancool)
i checked the files that prusa give you, on the parts i can see R5
so i guess they fix it
Opublikowany : 07/05/2020 6:34 pm
lee.g
(@lee-g)
It's possible they have updated them now.  I can't remember but i don't think R5 was there when i downloaded.
Opublikowany : 07/05/2020 6:37 pm
