Original Prusa i3 MK2.5S vs MK2.5 + important links
Hello all;
it is very important to learn the difference between the Original Prusa MK2.5S and the Original Prusa MK2.5, as they aren't the same printers!
- MK2.5 uses B7/R3 (revision numbers that are on the printed parts) extruder design with Optical filament sensor => Needs its own MK2.5 firmware
- MK2.5S uses different extruder design and brand new IR-sensor => Needs a different MK2.5S firmware
Please keep this mind! Flashing incorrect firmware will cause issues with the IR-sensor!
The differences between the The Original Prusa MK2.5S / MK2.5 is the filament sensor as stated above, if you have any concerns about identifying your printer, please feel free to contact our support department via live chat and e-mail in several languages. Below is listed our home page(s) for the MK2.5 / MK2.5S where you will find the following:
- Firmware
- Drivers & Apps (includes PrusaSlicer)
- Printable parts
- Assembly manuals
- 3D printing handbook
- Helpful articles and guides
- ...and a lot more
Example of the homepage for MK2.5S
Homepage for the printers:
Printable 3D models:
Example models (verified G-codes) that are shipped on the SD card are also provided in our drivers and app package and can be downloaded as a part of the Drivers & Apps package, which is available here:
prusa3d.com/drivers
If you want to explore a lot more designs that our community has submitted, make sure to head over to www.printables.com and explore hundreds of thousands of designs
Spare Parts
- MK2.5/MK2.5S/MK2.5S+ spare parts section www.prusa3d.com/category/mk2-5-mk2-5s
The following is our guide to set up and calibrate our i3 printers. This video features a MK3, but the set up and calibration process is similar to the MK2 / MK2s / MK2.5 / MK2.5S
Introduction to the MK2.5/MK2.5S series and features
The video is in English but includes subtitles for IT, PL, ES, DE, FR, CZ languages.
Click on the "CC" icon in the lower right corner
/ Knowledge Base
Re: The most important links - Original Prusa i3 MK2.5
Hi Jakub,
a projected delivery timetable would be good
mk3's ordered this year, seem to be shipping before upgrades ordered last year!
Hi Joan,
so far we have a shipping table for the MK3 ( https://help.prusa3d.com/l/en/article/6OdtbKF1bw-shippingtable ). We've sent some kits prematurely due to new packing and shipping system.
/ Knowledge Base
Hi there,
I just have a crazy question : on Slic3r, should I keep my MK2S settings... or move to MK3 ?
Thank you.
PIierre
Hi Pierre,
please use MK2S profiles for your MK2.5.
/ Knowledge Base
Hi Pierre,
Just upgraded my Mk2S to a MK2.5 and installed firmware 3.2.1. The first prints have come out really bad.. starting to troubleshoot right now but before I get to crazy with that can you please confirm this is the right Slicer profile that I am supposed to be using? I am a little confused because I don't see a specific "MK2S"option anywhere
I have a MK3 and a MK2.5 now, so I selected this option from the configuration assistant
From these options, I selected "Original Prusa i3 MK2"
My MK2S printer did spend some of it's life as a MK2S Multi Material (original version) and had that firmware on it for a while.. don't know if that matters in any way.
Is this correct?
Thanks!
Hi Jakub,
is there a link to the scad files for the MK2.5 upgrade parts?
Hartmut
This what i find on git.
https://github.com/prusa3d/Original-Prusa-i3/tree/MK2.5/Printed-Parts
Gert
Thanks
Re: Original Prusa i3 MK2.5S vs MK2.5 + important links
Are the extruder and filament sensors the only difference between 2.5 and 2S ?
How to upgrade the 2.5 to 2s?
Is the MMU2 upgrade compatible for both?
Sorry, I mistyped. I have the 2.5 already. I am wondering about the difference between the 2.5 and the 2.5s.
Will the MMU2 upgrade be compatible to both?
RE: Original Prusa i3 MK2.5S vs MK2.5 + important links
@grandpajoe
sorry this is a late reply, I am sorting some 'Spam' posts and saw this was unanswered
you need the mk2.5s for mmu2s
mk2.5 works with mmu2
I have been offered a 2.5S second hand. How will this compare to a Mk3S?
I have been toying with Mk3S and mini. I want to do strong working parts so I would like to use nylon, petg, and pc (plus other strong materials I have missed).
I just wondered what the advantages of a MK3 over the MK2.5s would be.
All help appreciated.
Regards
Mick
Copy / paste from the Prusa website, theres are the main differences:
- Brand new EINSY RAMBo motherboard
- Silent Trinamic drivers with 256 microstepping
- Max travel speed: 200 mm/s
- Sensorless homing for X and Y axes
- Improved frame rigidity with aluminium extrusions
- Power loss detection and recovery
Homepage for the Prusa MK2.5S / MK2.5
