MK2S->MK2.5, MMU1, MMU2 - which order?
Heinz
(@heinz-3)
Good evening everyone,
I am a proud owner of an MK2S. In addition I have the MMU1 upgrade still in the box (i.e. not yet installed) and also the MK2.5 upgrade kit still in the box (i.e. not yet installed). I understand that those two upgrades would enable me to also get and install the MMU2.
What I do not quite understand, though, is the exact order of these three upgrades. Do I have to install the MK2.5 first, then MMU1 and MMU2? Or first the MMU1, then the MK2.5 followed by the MMU2?
Kind regards,
Heinz
Postato : 06/09/2018 8:04 pm
Nikolai
(@nikolai)
Re: MK2S->MK2.5, MMU1, MMU2 - which order?
Actually you need to decide which upgrade you want to install. Following combinations are possible:
1. MK2S + MMU1
2. MK2.5 + MMU2
So in your current setup one of the upgrade boxes can't be used.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 07/09/2018 7:56 pm
Heinz
(@heinz-3)
Thanks Nikolai.
As have the MMU1 upgrade available it concluded from the shop page that I can use the upgrade kit from MK2 MMU to MK2.5 MMU2. Having also cast a look into the online manuals it seems that in essence I have to first upgrade my single-material MK2S printer to MK2.5 and then install the MMU2 as a combination of parts from the MMU1 kit for the MK2 + the MMU2 upgrade kit (MK2 -> MK2.5).
Does this sound right?
Postato : 08/09/2018 8:09 pm
Nikolai
(@nikolai)
Correct. You need in addition this MK2S->MK2.5 upgrade kit and this MMU1 -> MMU2 upgrade kid
End result will be MK2.5 with MMU2
Often linked posts:
Real Multi Material
Postato : 09/09/2018 12:16 am
