first Layer on Supports
docsascha
(@docsascha)
Hi
Just wondering if there is a solution for this
When I print and using supports for, the first layer printed on the support structure always looks a kind of "stringy"  like in the picture
When I do bigger structures on supported areas, the 1 layer often has loose strings and does not look that good connected to the next layer
Is there any solution to this?
BW
Sascha
Opublikowany : 06/12/2020 5:46 pm
Clemens M.
(@clemens-m)
RE: first Layer on Supports
I think that is normal - the only way to avoid this is to have a look at the orientation of the part. If you take a look to the knob in your photo I would print it so that the surface facing the person pushing or rotating the knob is not printed on supports.
Best regards, Clemens
Opublikowany : 11/12/2020 10:17 am
towlerg
(@towlerg)
I seem to remember reading somewhere that Cura handles that a little better. YMMV
Opublikowany : 11/12/2020 12:53 pm
