z adjust calibration issues
Wosgien
(@wosgien)
My printer started as an MK2s ,then mmu1, then MK2.5S and mmu2s upgrade at same time no errors at any time during upgrade even mmu2 calibration.
all calibration  tests successful , but when trying to print first layer z adjust, no movement on x axis and a blob of filament at home position
tried to print some things  through SD same issue of no motor movement?
it also does the same thing from the LCD menu and not wizard.
 motors are homing and  z calibration through  the XYZ calibration sucessful.
This topic was modified 7 years temu by Wosgien
Opublikowany : 08/08/2019 8:48 pm
