Upgraded to Mk2.5S, thermal runaway every time the fan turns on
Hobby Hoarder
(@hobby-hoarder-2)
Had thousands of hours on Mk2S, then a few hundred on Mk2.5, no issues. I just upgraded to Mk2.5S yesterday and while everything seems to work, I'm getting runaway error every time the part cooling fan turns on. The hotend temp. drops by 15'C immediately.
It does seem that the fan exhaust is pointing higher on the heater block as it did before (or I have a bad memory). Here's how it looks:
The radial fan is not stock (died long time ago), so maybe it's too powerful with the new exhaust? As I've said, it was fine for hundreds and hundreds of hours before, so I can't think of anything else.
I haven't tried tilting the exhaust downwards more, I'm not sure I even can.
Posted : 01/04/2019 4:20 pm
Milos V.
(@milos-v)
Re: Upgraded to Mk2.5S, thermal runaway every time the fan turns on
Sure you can slow down the fan. Or I would recomend the silicon hotend sock. It solves the problem.
Posted : 01/04/2019 6:26 pm
Gt6k
 Gt6k
(@gt6k)
+1 for silicon sock. I use these and it limits the temperature drop to no more than 2 C at ABS temps and it recovers within a couple of seconds.
Posted : 01/04/2019 10:49 pm
hammybe
(@hammybe)
I am having the same problem using the stock print fan. I was able to solve the problem by lowering the fan speed below 80%. The temperature still drops by 10 degrees or so when the fan comes on, but it is able to recover after a minute or two.
Definitely going to try the silicone sock to see if that helps too.
Posted : 12/04/2019 4:28 pm
Knickohr
(@knickohr)
Member Moderator
Put blue socks on an do an PID-calibration for extruder and bed.
Thomas
Posted : 15/04/2019 11:23 am
I'm having the same issue since upgrading to mk2.5s this week. Very annoying to require lowering the fan speeds to get it to work right. If a silicon sock is needed, it should have been included in the upgrade kit. Does anyone know of a solution besides using a sock??
Edit: also, i ran the PID and temp calibration but didn't fix anything.
Posted : 16/04/2019 6:21 pm
Milos V.
(@milos-v)
PID calibration is good to make after you put the sock on. There are several threads on the forum because of this, it is also related to MK3S. So far the sock is only thing that works. I am just suprised, that there are not much often questions on this. From my point of view this has to limit everybody. So why just only a couple of people is complaining about?. All the new users of the printers, and that has to be tousands of them, should have this issue. Most of them newbies. I would expect much more complains and proper actions from Prusa. Like having the sock as a default accessories and coming with the printer.
The printer is realy aborting the print because of this. Sure not everytime. The big drop down causing temp runaway error is happening only on the bottom layers (the air is coming not just directly from the fan but also get bounced from the heated bed) and therefor it influents especialy PLA prints, where fan starts with second layer (at default Slic3r profiles)
Milos
Posted : 17/04/2019 5:09 pm
AliOuk liked
Nikolai
(@nikolai)
Yes, it's same on my MK2.5. With the current fan/extruder design you have only this three options (from best to worst):
1. Sock -> stable temp, good cooling
2. Lower fan speed -> stable temp, worse cooling
3. Aggressive PID values (PID calibration with 50% fan speed) -> slightly bouncing temp -> good cooling
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 17/04/2019 5:36 pm
MakingThingsCLT
(@makingthingsclt)
RE: Upgraded to Mk2.5S, thermal runaway every time the fan turns on
I'm having the same problem. Old gcode that turns the fan on after the first few layers causes thermal runaway as soon as the fan kicks on. Resliced with no cooling fan and the problem goes away. This looks like a pretty big oversight, honestly. I don't quite have the chops to redesign the fan duct to aim lower but I assume someone out there is looking at it.
Posted : 28/04/2019 2:38 pm
AJ West
(@aj-west)
We're discussing it here: https://github.com/prusa3d/Prusa-Firmware/issues/1746
Posted : 04/05/2019 1:07 pm
jlorenzi
(@jlorenzi)
I didn't have any luck until I hit 50% fan speed.
This is really a horrible design issue that every MK25.S owner will run into right after they just spend all day wrenching on their printer. So of course they're going to think they screwed something up.
I spent 5 hours futzing around with things until I finally hit on the right google search where I found the solution. That is really crappy. They've had two years to fix this design, why isn't it fixed yet?
Posted : 08/11/2021 12:39 am
You liked
Chicago Keri
(@chicago-keri)
This happens to me when the heater cartridge is starting to fail. Replacing the heater has solved it for me 2 times, with many hours of prints before the heater starts acting up.  The first symptom was always Thermal Runaway upon parts cooling fan activation.  A sock appears to work for awhile but it worsens over time.
The heater resistance goes high, reducing the heat output.  This can be checked at the MiniRambo with an ohmmeter.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Posted : 22/11/2021 2:36 am
jlorenzi
(@jlorenzi)
The silicone sock around the print head worked fine for me, so I just went with that. I have a spool of ASA so I downloaded a fixed nozzle from the Prusa model web site, and it printed fine. I never installed it though because the silicone sock worked so well.
However, I am in the middle of a full Bear upgrade and I did change out the heater for a 40W one (stock is 30W) from printedsolid.com. I also changed out the hot end for a nickel plated copper one, changed out the nozzle for nickel plated copy, and changed out the heat break to a titanium one. So, we'll see how all these upgrades turn out in the end.
I do think it's really ridiculous they haven't fixed this design, as it's been over a couple of years now.
Posted : 22/11/2021 2:43 am
