MK2.5S Upgrade -Left Hotend Fan wiring error
kitefiter
(@kitefiter)
I recently finished the installation of the MK2.5S upgrade.  Relatively easy until I updated the firmware.  I got the Extruder Fan error.  I fell for the problem without checking the forums (duh) and ordered a new fan.  Wait 10 days. After installation of extruder fan, I get Left Hotend wiring error.  I order a new Noctua fan and wait 10 days.  I install the new Noctua fan but now I still get the Left Hotend wiring error.  I pull everything apart and check every single wire and connection.  I apply 6v to the fan to make sure it is working.  I don't really know what to check.  I am going to try going back to the original firmware before all of the fan check nonsense and see if that fixes the problem,
Any suggestions?
Opublikowany : 06/07/2019 1:01 am
Dave Avery
(@dave-avery)
RE: MK2.5S Upgrade -Left Hotend Fan wiring error
you can get the fan speed readings under the support menu and you can set the speeds in the settings menu for testing
Opublikowany : 06/07/2019 1:55 am
kitefiter
(@kitefiter)
The fan is never making a connection.  I have removed the cable and supplied power externally and the fan works fine.  Something is wrong with the cable connection at the minirambo board.  The connection seems loose and floppy.  I will try making some new connections to make sure.  I'm afraid I may have damaged the socket in the board when I tightened the door with all of the cables inside.
Opublikowany : 07/07/2019 7:26 pm
kitefiter
(@kitefiter)
I tried a third party Noctua fan and still had the error.  I ordered a fan from Prusa, and voila, problem solved.
This post was modified 7 years temu by kitefiter
Opublikowany : 18/07/2019 6:04 pm
