Missing layers fault after upgrade - solved
Hi, I thought I'll share this info with you, I've finished upgrading my printer from MK2S to MK2.5 and after one print, my printer was missing layers. Here is what I did to resolve this.
https://vio.net.au/3d-printing-missing-layers-not-extruding-solved/
I believe the 20mm pin provided is too short.
Hope this helps you.
Vio
Opublikowany : 11/06/2018 6:53 am
Re: Missing layers fault after upgrade - solved
good analysis!
nicly done! 😎
thanks for sharing the info.
Opublikowany : 17/06/2018 4:49 pm
Seriously brilliant!!! A simple solution to a pretty significant problem. I too noticed that my pin (MK2->MK3 upgrade kit) looked a bit short and will implement your solution. I was a bit skeptical when I installed it. Thanks!!!
Opublikowany : 20/07/2018 8:49 pm
