Magnet sizes and sources
steven.schmelling@gmail.com
(@steven-schmellinggmail-com)
Hello all.  I'm a bit late to the party.  But I decided to finally upgrade my 2S to a 2.5S.  I used the free shipping this last weekend to order all the parts individually from Prusa that matched this sheet.  https://help.prusa3d.com/en/article/upgrading-mk2-s-and-mk2-5-s-to-mk2-5s_20000
Looking at the other parts I need, i think by reusing many from the 2s, and some screws I have on hand, there won't be too much extra things I need.  But I believe the stainless steel ball, and the magnets are going to be a couple (off the top of my head I don't know of anything else).  I can source the 7mm SS ball on amazon.  But I'm having a tougher time with the exact size magnets.  Do you folks think that 5mm wide ones would work with a shim in the slot?  And does anyone see a problem with cutting down a 20mm long one to make a 10mm one?  I also assume these are just normal magnets, and not rare earth/neodymium ones, correct? Or alternatively if someone knows a good source for the correct size magnets (20x6x2 & 10x6x2) at a reasonable price and shipping time, I'd be interested in that as well.
Thanks in advance folks,
Steven
Opublikowany : 01/12/2021 12:18 am
Moderator
RE: Magnet sizes and sources
Chinese filament sensor kits are cheap enough on ebay or aliexpress...
Opublikowany : 01/12/2021 12:44 am
Eggs polubić
Thanks Joan.
I didn't know the kits came with both the magnets and ss ball before.  I think you are right, I will just order one of those.  I even see one of the Polish ones on the US Amazon store.  I sorta wish I had noticed that before ordering all the other parts from Prusa, but now I will have an extra sensor (think it is 12v).
Well at least this post is here for the next person who tries to do the same thing.
Steven
Opublikowany : 01/12/2021 1:10 am
Eggs polubić
Moderator
the sensor will be 5volt
Opublikowany : 01/12/2021 11:25 am
Daugherty
(@daugherty)
Magnetism is caused by the motion of electric charges. Every substance is made up of tiny units called atoms.
UPSers
Opublikowany : 23/02/2022 4:43 am
