Just finished upgrade to 2.5s. X axis not hitting switch
bryan.d4
(@bryan-d4)
I finally got around to installing the 2.5s upgrade. Everything seemed to go together without any problems.
However, not that I'm trying to get things working, the calibration is failing because it's never hitting the switch on the X-axis. When the print head is all the way over, it's not even close to hitting the switch. We're talking several millimeters gap.
I'm not sure what to change to make it work. Everything seems to be exactly where it's supposed to be, but it just won't work.
Any ideas?
Napsal : 31/03/2019 11:28 pm
Milos V.
(@milos-v)
Re: Just finished upgrade to 2.5s. X axis not hitting switch
Check if you did not miss Step 65 Endstop-block assembly
https://manual.prusa3d.com/Guide/3.+E-axis+assembly/1150?lang=en#s20788
Napsal : 01/04/2019 1:15 am
Milos V.
(@milos-v)
That Endstop-block goes directly to the x axis end stop switch. If endstop-block is there but not reaching the switch, then you made a mistakne in the extruder cables arrangement in the back, usually the zip ties are wrongly placed and are preventing the extruder to go fully left.
Milos
Napsal : 01/04/2019 1:35 am
