[Solved] IR-Sensor failed after upgrade from 2.5 to 2.5s
DoctorRudd
(@doctorrudd)
Hello All,
after upgrading, the Wizard failed at the point of ir-sensor checking ("check wiring...). After checking the wiring and redoing the wizard, same error message.
I unscrewed the sensor from its housing and did the test again. I could here a very little noise from the rambo board, that changes when I put a cable tie into the gap of the sensor module. Higher pitch when nothing is blocking the IR-signal, lower pitch when IR is blocked by the cable tie.
It seems the the sensor is sensing something. Any ideas to fix the problem? Spare parts are actually not available.
Best regards, Peter
Best regards, Peter
Napsal : 29/04/2020 2:02 pm
DoctorRudd
(@doctorrudd)
RE: IR-Sensor failed after upgrade from 2.5 to 2.5s
Solved, flashed the wrong firmware first. 😎
Best regards, Peter
Napsal : 05/05/2020 10:06 am
