Important when upgrading to 2.5S
ARDI
 ARDI
(@ardi)
I upgraded to 2.5S and earlier I could use silent mode for a full print, but that is not possible anymore since it introduces Y-axis layer shifts. And like everyone else I've gone through all conceivable reasons and checked the printer meticulously to ensure that everything else is OK. The printer has to be set to high power mode for all prints.
Also, the calibrating failed on the eight point until I found an (at that time) unofficial formware on github which solved the problem, so make sure to use the latest firmware (in this case https://github.com/prusa3d/Prusa-Firmware/releases).
/A
Postato : 17/05/2020 9:04 am
