First layer issues
I got a 2nd hand Prusa MK2 I am using PLA, I replaced the PEI coating on the heat bed. Trying to get the first layer to smooth out I get this.
It looks like I may need to go lower. But i am already at -0.180. Does that sound and or look right?
Best Answer by JoanTabb:
it's difficult to say...
ripples normally mean live Z is too low...
But you can also get ripples if live Z is way too high,,,
I would initially try live Z as a smaller negative number, and see what happens
RE: First layer issues
ripples normally mean live Z is too low...But you can also get ripples if live Z is way too high,,,
I was way to high, I dropped it almost 4x what it was and it started to clean up. Guess the new PTE sheet was thinner. Thanks for your help!!
