Fimware upgrade Times out and fails
TURTLE_HARDBODY
(@turtle_hardbody)
Finished the assembly of the MK2.5 upgrade and am now trying to flash the MK2.5 firmware through Slic3r PE. I received the following error:
avrdude: Version 6.3-20160220-prusa3d, compiled on Jun 12 2018 at 12:57:13
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/PROGRA~1/Prusa3D/Slic3rPE/resources\avrdude\avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_recv(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
What I have tried:
  • Different USB ports on the same PC
  • Different PC's
  • Running Slic3r PE as admin (on both PC's)
  • I'm not sure what else I should try at this point, any ideas?
    Thanks!
    Publié : 26/06/2018 12:26 am
    rohan.w2
    (@rohan-w2)
    Re: Fimware upgrade Times out and fails
    I had the same problem. Finally solved it. Open a command prompt as administrator.
    (Spam links removed)
    Any solution update from you.
    9apps.ind.in/
    Publié : 06/10/2018 3:56 pm
    ST
     ST
    (@st)
    RE: Fimware upgrade Times out and fails
    Hello I tried this, but didn' t work, any help would be welcome
    servane
    Publié : 28/09/2019 10:48 am
