Extruding when loading but not printing
Had a clog. Partially disassembled extruder to make sure nothing was stuck by the extruder gear.
After reassembly, ran self test, all OK.
Preheat and load filament. PLA flows nicely from the nozzle.
Next, try printing. Purge strip comes out a bit, but blobby then nothing. Initial loop runs then print starts, but almost nothing is coming out - just a little bit of stringing.
I've been through Z offset adjustment before, and this didn't look like low or high Z.
If there are no other suggestions I guess my next step is to change the nozzle. I'd appreciate suggestions for anything else I should try.
Posted : 18/08/2023 3:04 am
