Extruder calibration
nick.c16
(@nick-c16)
So, I have finally got my freelance i3 built. I had trouble calibrating XYZ until I replaced the Pinda probe with one supplied by Prusa. I have a Rambo mini board that came pre loaded with firmware. I bought the V6 hotend from E3D, along with their 'Small but Mighty' stepper motor. The motor is built for steps of 0.9 deg. I asked the place I got the Rambo from to alter e-steps/mm to correct value for 0.9mm steps when they preloaded the firmware. I am getting nowhere with extruder calibration. E steps are set at 837 steps/mm according to m93 in Pronterface. Any one any ideas what setting should be? If I were to swap E3D motor for a std 1.8 deg motor what would be a good starting point for number of e steps? I hope it is ok to ask here as I didn't buy all the parts from Prusa..
Veröffentlicht : 19/08/2018 7:43 pm
RetireeJay
(@retireejay)
Re: Extruder calibration
My standard 1.8 degree stepper calibration for the extruder is 280 steps/mm. So if you are using the same Bondtech geared extruder then your steps should be exactly twice that: 560 steps/mm. Of course you can precisely calibrate your extruder by measuring the actual filament consumed when you give a command (or series of commands) to extrude, say, 50 or 100mm. I've never felt the need to do that on my MK3 because it just worked right from the start.
Veröffentlicht : 19/08/2018 8:21 pm
