How to remove MMU2 unit
Matěj Hájek
(@matej-hajek)
Hello, I have MMU2 on MK3S. I broke the MMU and want ro remove it.
Can I just Unplug it from electronics board, remove the PTFE tube and take it of the printer?
Of must I modify something or update firmware?
Thank you for answering 😊
Napsal : 06/01/2022 6:01 am
Yes, although your filament sensor will not work unless you reinstate the old one.  This is only a problem when you're getting close to the end of a  roll.
Just use the plain MK3+ profiles.
Napsal : 06/01/2022 9:18 am
