XL with .8mm nozzle retraction settings
Eddy
 Eddy
(@eddy)
Long story short - I damaged the .6mm nozzle the XL came with (tightened the setscrew too much - sigh)  and the only other one I had was a .8mm nozzle. I changed the profile to "Original Prusa XL 0.8mm nozzle" and printed with the default print settings for "0.4mm QUALITY", the only thing I added was a "Variable layer height" modifier. I'm using Overtures's light grey matte PLA (disregard the black Flex print, I did that on the Mk4)
As you can see on the pics, there is definitely something going on at either the end or start of each layer . I know it's a retraction settings issue but can't figure out if its at the end (coasting) or at the re-start of each layer.
Has anyone tried using a .8mm nozzle with PLA on the XL? or have any suggestions as to what setting I should be focusing on?
Thanks in advance for any advice!
Eddy
Respondido : 26/06/2023 4:00 am
I've printed a few things with a 0.8 nozzle on my XL last week and was surprised by the great quality of it. Basic settings but 3 perimeters.  I didn't see any of the issues you're experiencing. Having said that, I was using PETG, not PLA.  I have seen similar gaps at the seams with my Mk3S and 0.8 nozzles before. Interestingly, it only happened with a particular brand so I never tried to fix it, I just changed brand. But I think the problem is not the end of the layer but that de-retraction at the beginning so I'd start there, I guess
Respondido : 26/06/2023 1:26 pm
Eddy
 Eddy
(@eddy)
RE: XL with .8mm nozzle retraction settings
Thank you Fuchsr! I was also leaning towards starting to adjust the de-retraction settings first. I went ahead and printed another one with all the retraction settings turned off and also aligned the seam to see it a little better (better pics attached but disregard the big seams, that's just where I ran out filament and had to change rolls). I'll also try and find a smaller (faster) model to test any new settings out with.
Btw my replacement .6mm nozzle came in today - yeay! but I think I'm going to go ahead do my homework - leave the .8mm nozzle in and take the time to tune it for future use.
Cheers,
Eddy
Respondido : 27/06/2023 3:36 am
Please keep us posted!
Respondido : 27/06/2023 10:41 am
