I can literally watch my ASA print warp after removing it
heyPJ
(@heypj)
Opublikowany : 19/04/2025 5:46 am
heyPJ
(@heypj)
RE: I can literally watch my ASA print warp after removing it
I’m trying to print this model. It takes up most of the build plate of my XL and it’s about 10mm thick. I’m using glue stick and I have the Prusa enclosure. I pulled it off and it was perfectly flat. As I was changing filament and loading my next print it warped. I've had the cooling fans both on and off. I upped the bed temp. Not sure what to do next. Any ideas? Thanks in advance.
Opublikowany : 19/04/2025 5:56 am
LarGriff
(@largriff)
Looks like it adhered to the bed quite well during the printing, so that’s good.
Just guessing here.  Maybe leave it on the bed until after it cools?  Or, if you had flipped it over after you removed it, would it have warped the other way?
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 19/04/2025 3:45 pm
heyPJ
(@heypj)
I’ve had them finish in the middle of the night so they’ve had a chance to cool slowly. I was thinking about trying solid infill thinking maybe it would cool more gradually.
Opublikowany : 19/04/2025 4:14 pm
Chris Hill
(@chris-hill)
Could you put a heavy weight on it while it cools? Perhaps remove the build plate from the printer with the print still attached, place it somewhere flat and put a large flat weight on top?
Opublikowany : 19/04/2025 6:34 pm
heyPJ
(@heypj)
I’ll give it a try on the next one.
Opublikowany : 19/04/2025 6:58 pm
You can try annealing, with mostly flat parts it often works well:
Constrain the part (perhaps by loading it with weights) and put it into an accurate oven or other heater, raise the temperature to the glass transition temperature of the material (manufacturer's data sheet) and keep it there for long enough to heat all the way through.  Allow to cool slowly, when cool remove the constraints.
Afterwards measure the part carefully as sometimes resolving the warping stresses can resize the part - this is another occasion where calibrating any changes back into the original CAD may be worthwhile.
Opublikowany : 19/04/2025 11:12 pm
Cotano
(@cotano)
Posted by: @diem
This would be my recommendation.
Opublikowany : 28/04/2025 4:39 am
Bimberle
(@bimberle)
If you don’t have an oven for that you can also use a heatgun and some clamps. Just be careful not to overheat the part and selectively.
Opublikowany : 28/04/2025 8:03 am
heyPJ
(@heypj)
Haven’t tried the annealing but I redesigned the part to be slid in and not screwed together. I didn’t mention this but, you can see it in the pictures, the edges print well. It lifts in the middle. The top which had been printing great (basically a 10mm thick wall that takes up most of the XL build plate) was a disaster. I upped the infill to 100% just to see if maybe it would cool more evenly. The part that is the subject of the post (the base) looks great when the print finishes but then you can hold it in hand and watch it warp. This time I removed it, thought I was home free, and it started warping. I put it in the sink and ran cold water over it while pushing down of the middle. That was working and it didn’t warp as much. So the annealing and the top pressure may be something. I’m on hunt now for a cheap used (for powder coating and now annealing 3D prints) oven so I can try annealing the base. Thanks for all the replies.
This post was modified 1 year temu by heyPJ
Opublikowany : 03/05/2025 1:08 am
I have not tried this but your post made me think ...
For PLA and perhaps PETG it should be possible to anneal in hot water; it's certainly worth trying with PLA, a flat bottomed bowl of water at about 65°C, a weight, and allow the water to cool with the part.
Opublikowany : 03/05/2025 3:33 am
OK, I have now tested PLA and it seems to work - so ASA is worth testing with boiling water.
Opublikowany : 03/05/2025 11:52 am
1 ludzie polubili
jjspringate
(@jjspringate)
Hi HeyPJ,
I am have a Prusa XL (Twin head) and I am looking to print some medium to large ASA parts for an outside light fitting, with a camera hidden in its base.
I just printed the first piece, 230x75x35mm, and what a mess!!  It has warped badly during printing, has very rough surface finish towards the ends and about 10%  has totally failed.
I have made an enclosure, modified from the Voxel 3D, designed by Sander Hesp.  Which is OK but does not cover the rear vents of the XL.  Also it has no internal heat or control for the enclosure.
So I am very much starting at the bottom with this project, and any tips would be very helpful.
In particular, what mods/tricks did you find gave you the most benefit.
Opublikowany : 13/03/2026 5:26 pm
