XL will not read exfat formated USB
Bob Ruff
(@bob-ruff)
Tried to print some gcode files (Pruseslicer) I copied to a new Samsung 158GB USB flash drive. The XL would not open it. Checked on my computer the files were there. What is going on? I'm I missing something?
Napsal : 11/08/2023 10:16 pm
Virgil
(@virgil-2)
RE: XL will not read exfat formated USB
Similar discovery. I had a stubby Samsung drive that I thought would be ideal as less chance to bump.... Seems only fat32.
I then reformatted it to fat32 specifically for the XL, it recognised it and I had some success; I'm using Prusa Link/Connect to wirelessly transfer but the results were really erratic so have moved back to a native fat32 usb and resolved.
Napsal : 12/08/2023 12:20 am
jvasileff
(@jvasileff)
That's right - exFAT is not supported. https://help.prusa3d.com/article/sd-cards-and-usb-drives_112291
It would be nice though if the printer would report an error rather than showing and empty drive.
Napsal : 12/08/2023 1:14 am
None of the buddy based printer do. GitHub issue here https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3011  it seems the devs are using the tiny usb library for usb support. Which does not support exfat.
Napsal : 12/08/2023 7:09 am
Holck
(@holck)
Im no expert...just glancing, but tinyusb does seems to use FatFs as the filesystem module, as does the Buddy code: https://github.com/hathach/tinyusb/blob/master/lib/fatfs/source/ff.c
and
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/src/buddy/filesystem_fatfs.c
FatFs does support exFAT: http://elm-chan.org/fsw/ff/00index_e.html
Its enabled in the config code of the project by setting FF_FS_EXFAT to 1
http://elm-chan.org/fsw/ff/doc/config.html#fs_exfat
Enabling exFAT does seem to require you modify your filename code
Napsal : 26/08/2023 7:35 pm
Makak007
(@makak007)
Thank you all! This thread pointed me the right direction solving my problem I described here:
https://forum.prusa3d.com/forum/postid/758874/
I used exFat formatted drive with no issues until the last fw upgrade (6.2.5), then skipped lines problem popped up.
As for the USB formatting:
Format USB drive properly as (and only as!!!) FAT32, Primary partition and set to Active - this condition is often not mentioned! If not set to Primary and Active, you won't see the USB in XL printer (same applies to other Prusa models too). I used MiniTool Partition Free for formatting the USB stick (here you can easily compare the format settings of the original Prusa USB supplied with the printer and your new USB stick).
I think the devil hides in similarity of exFat to the older FAT32. As Neophyl pointed out, devs use libraries which probably conflict in some aspects with exFat newly added features (in relation to FAT32). Deceivingly, exFat (if set Primary and Active) will be recognized by XL printer and may work flawlessly if conditions are right. But it is a problem waiting for it's chance... So, never exFat, only FAT32!
Napsal : 25/07/2025 11:48 am
1 lidem se líbí
