Prusa XL crushed my print at 100%
Jerrari
(@jerrari)
My XL seems to do a series of incorrect motor movements after reaching the end of my print. It lowered the print as it usually does at the end of the print, re-homes the nozzle in the front left before slowly moving backwards, meanwhile the build plate proceeds to raise the print bed up and unlocks a secret crushing mode.
I was able to cat the disaster on my camera here:
Is there a way to pull an event log from the machine to see what happened?
Opublikowany : 23/01/2024 11:58 am
Brian
(@brian-12)
RE: Prusa XL crushed my print at 100%
You've found the secret Easter egg!
Now contact service and send them the G-Code file to claim your prize!
At least you caught it on camera.  You'd  definitely be scratching your head trying to figure out what happened without it.
Opublikowany : 30/01/2024 1:30 am
