Power Panic
Geoff
(@geoff)
Power Panic
Does anyone know what the output on the power panic line from the PSU should be for "power good" and "power fail"? My new XL won't go beyond a "power panic" error.
The knowledgebase says that the printer won't work if the cable is disconnected so there must be some sort of active signal on the line. I have checked the PP cable for open circuit or short circuit.
Publié : 15/11/2023 10:57 am
Hello
(@hello)
RE: Power Panic
Posted by: @geoff
I believe you leave the black wire connected and the white one disconnected or vise versa isn't better to get replacement from prusa anyway
Publié : 15/11/2023 6:18 pm
Geoff a aimé
Geoff
(@geoff)
RE: Power Panic
Thanks for the info: 6 hours on Prusa chat failed to elicit that information! Unfortunately it wont solve my problem because the cable actually tests fine, I think my problem lies on the main board.
Regards
Publié : 16/11/2023 7:51 am
Hello
(@hello)
RE: Power Panic
Posted by: @geoff
Regards
Yeah exactly leaving 1 wire disconnected will stop the signal but confirm the cable is in I just carnt rember if it's the white or black you take oug so maybe try both
Publié : 16/11/2023 8:00 am
Geoff a aimé
EliwazMoonitz
(@eliwazmoonitz)
Membre
RE: Power Panic
I too have been having this trouble as well now that got my printer an built it an all they keep asking me is show me a pic ect an what is the power panic cable an I say why don't they already know it's there machine. I may try this cut of wire an see too as there so called help has left me more angery an tired. I hope you at least got yours fixed if not I will post here latter after test it for you.
Publié : 22/03/2024 9:00 pm
E-Claus
(@e-claus)
RE: Power Panic
Hello !
Try this (swap the power-supply-unit, left with right at the back of the printer)
https://help.prusa3d.com/de/guide/auswechseln-eines-netzteils-xl_632397    (german)
I made this an had no longer the power-panic-error
Publié : 12/04/2024 11:55 am
