Clicking pulleys
Erik
 Erik
(@erik-3)
Clicking pulleys
I noticed that after 17 days of print time on my XL the pulleys on the right side of the Core XY are clicking. I replaced the pulley that is attached to the belt tension adjustment screw, but the pulley that is on the linear rail is also clicking. Does anyone know how to disassemble that piece to replace the pulley?
Also, 17 days of print time seems pretty low to have two pulleys fail. I purchased replacements from Printed Solid and they aren't actually the same part. The 1mm of extra diameter didn't make a difference in the tensioner pulley, and I'm hoping it won't make a difference on the other one.
Napsal : 09/12/2024 3:16 pm
Erik
 Erik
(@erik-3)
It looks like this may be the correct manual:
https://help.prusa3d.com/guide/how-to-replace-the-corexy-plastic-parts_265856
Step 41 shows removing the side covers, which should allow access to the assembly that is on top of the linear rails. Step 49 shows actual disassembly of the parts I need to replace.
This post was modified před 2 years by Erik
Napsal : 09/12/2024 3:26 pm
Erik
 Erik
(@erik-3)
RE: Clicking pulleys
I just replaced all 3 pulleys, since I had it apart already. It resolved all of the clicking from the right side of the Core XY. For anyone else that comes here, the Prusa XL smooth pulleys are 17mm in diameter. The generic ones from Printed Solid (and all over Amazon) are 18mm. These did fit, but the clearance was TIGHT. No rubbing on any plastic parts.
Napsal : 09/12/2024 7:19 pm
Dutch
(@dutch-2)
which idlers did you get on amazon? I added all the original ones on Prusa but dang they treat them like they are made out of gold
Napsal : 04/02/2026 5:52 pm
Erik
 Erik
(@erik-3)
I didn't get any from Amazon for my XL. I got them from Printed Solid. I just noticed that they look identical to the cheap Chinese ones all over Amazon that I've purchased previously for my MK3.
Napsal : 04/02/2026 9:40 pm
