X-Y shift during print
Harley D
(@harley-d)
About two hours into a print of 4 instances, the printing suddenly shifted 8.6mm in each direction along the X-Y Axes. This was at a height of 11.8mm ( layers set at 0.2mm )
I am having problems with filement cling to the extruder ( mentioned in another post ) but this seems so odd, I thought it would be a subject on its own. There was no warning that anything was wrong.
What would cause this problem? How could I avoid it?
Publié : 02/11/2025 8:02 pm
The most likely cause is one of your instances warping and lifting off the print sheet enough to cause a head-crash and consequent layer shift.
So: add brim, consider using 'helper discs' (mouse ears) and protect the printer from drafts.
Publié : 02/11/2025 11:41 pm
Harley D
(@harley-d)
Thanks for responding, but all four shifting exactly the same distance in both X and Y seems o me unikely because of a crash. If you have a look at the photo with the 4 in it, that shows the shifting.
How would a complete layer shift happen to all four? These were stuck hard to the sheet. Has the machine somehow re-calibrated the print? If so, then I don't see how brims or ears would have prevented the shift.
Harley
Publié : 03/11/2025 12:01 am
The parts are being printed simultaneously - it's effectively one big print.  A layer shift affecting one will always affect all.
Get the print sheet thoroughly clean, adopt the methods above and you should be OK.  If the problem persists come back and provide a copy of the project as a .3mf file
Files > Save Project as
Publié : 03/11/2025 1:01 am
Harley D
(@harley-d)
RE: X-Y shift during print
Hi Diem,
File attached as requested 🙂
Thanks
Publié : 03/11/2025 1:34 am
50% grid infill and increased infill/perimeter overlap - why?
After those above my next suggestion is to reduce the infill density and use cubic or even gyroid(will slow the print and shouldn't ordinarily be necessary for PETG.)
If you are trying to increase strength add another perimeter or two, it's more effective than infill.
Returning the infill/perimeter overlap to preset level or even a fraction lower should allow a little more internal stress relief.
Publié : 06/11/2025 5:23 pm
