RE: X-Carriage Upside Down?
Upside down compared to mine. Never took it apart though. Looks like its just 4 screws and the most annoying part will be re-setting your belt tension.
Respondido : 15/03/2025 9:58 pm
Topic starter
answered:
Thanks for the confirmation!
It wasn't that bad.
- loosen the two belt tensioners (screws on the front of the CoreXY assembly 4 turns (DO NOT REMOVE))
- remove the four screws on the front of the X-carriage. This holds down both belts and they will flop free.
- remove the screw from the back of the carriage plate. Note that there is a small metal bar that is under the screw that holds the whole thing in place.
- Flip, place small bar, and screw in the screw that holds the carriage plate in place
- Grab one of the belts and place the teeth up to the middle of the belt hold down. Screw that down.
- Insert the other half of the same belt into the hold down from the other side.
- You can use a flashlight to look through the little triangle window in the middle of the hold down. The ends of the belt should be touching.
- Once confirmed touching, screw down the other half of the hold down.
- Repeat with the other belt.
- Tighten the belt tensioners 4 turns (undo step 1).
That's it. I didn't need to re-tension the belts as the above restores them to the way they were.
Respondido : 16/03/2025 1:58 am
1 les gusta
