Second layer support issues
I'm trying to print a model with organic supports. The first layer looks good. The second layer (the next part of the circle) does not... It's as if it's too high maybe. Its not forming a complete circle and the supports are messed up from there on up. This has happened with two models so far.
Thoughts? suggestions?
Posted : 25/10/2023 1:42 pm
RE: Second layer support issues
I am also facing the same issue. The second and third layer is empty ... and then the support appearing in layer 4 and above.
Help ?
Posted : 18/01/2024 5:36 pm
found a related post ... follow up on the post below ...
Posted : 18/01/2024 9:49 pm
