No power at all
TJH
 TJH
(@tjh)
No power at all
Hmm, after getting my XL assembled, I turned the power on to discover that nothing happened!
The light on the power switch turned on (fuse is OK), but there's no power to the board (should be 24V DC) and no power to the extra AC outlet (120 VAC in the US).
I suspect a wire fell off the power entry module (where you plug the power in), but it's pretty un-obvious where to start dis-assembling things to look.
Any suggestions? I've been in touch with Prusa chat, but haven't received any detailed info.
Respondido : 21/09/2023 12:39 am
TJH
 TJH
(@tjh)
RE: No power at all
More info -- I removed the small cover from the power switches on each of the supply.
With the main power switch on (and lit), neither of the power supply lights turn on.
Working to dis-assemble more, but the PDU assembly is like one of those tavern puzzles you can't take apart.
Respondido : 21/09/2023 4:21 pm
TJH
 TJH
(@tjh)
RE: No power at all
Huzzah, figured it out. After taking off about half the screws in the back panel I figured out that removing the four M4 screws near the bottom from the inside releases the PDU. Pull it down to release/remove.
Take off a bunch of screws on the PDU assembly to remove the bottom cover plate to see the inside.
The problem is obvious and perfectly consistent with the evidence -- the wire just fell off the power entry module.
The other was about to fall out. I re-installed them and re-assembled.
Respondido : 21/09/2023 8:11 pm
3 les gusta
Xulunix
(@xulunix)
Miembro
RE: No power at all
Were the connectors loose?
If so, you might want to replace them or at the very least tighten them up a bit to create a good contact.
If the connectors are too loose, you get a high resistance which leads to heat and can cause fires.
If in doubt, contact support
Respondido : 21/09/2023 9:54 pm
TJH
 TJH
(@tjh)
RE: No power at all
The connections to the power entry module were loose in the sense that they were not fully pushed in (and fallen off). The crimps themselves are fine.
I just had to push them onto the tabs fully (and check the rest)
It's a little laproscopic to re-install the power distribution assembly -- you have to push it up to connect to the power supplies, then reach through the print area to get the mounting screws re-installed. Get a flashlight if you need to go this far.
Respondido : 22/09/2023 8:53 pm
Dante
(@dante-3)
RE: No power at all
Just to join the conversation.  I finished the assembly of the 5 extruder XL last night, turned it on and had no power.  The red light at the switch is on and there is a very slight and short flash of the LEDs in the enclosure.  It is so slight that if you are not looking right at it when you turn the switch on you wouldn't notice it.
I have not had time to check it out yet, but will be on it tonight.  Hopefully it is just as simple.
Respondido : 04/10/2023 11:57 am
TJH
 TJH
(@tjh)
RE: No power at all
If you see a flash of LEDs anywhere it's not the same problem as I had.
The manual doesn't describe the power distribution in detail.
The power distribution assembly takes line voltage in through a "Power Entry Module" -- switch and fuses. If the light is on, those fuses are OK.
Next it goes to a line filter inside the assembly, then to the output (socket) IEC connections. Two of them go to the power supplies, one is for some future expansion.
Each of the power supplies has a switch and fuses. They have little covers on the right (when viewed from the back). If you remove the screw, you can see the switch and fuse holder for each supply. If the light is on, the supply and fuse are fine.
The output of the supplies goes two places. The left supply (when viewed from the back) powers the board in the back. The right supply goes through the drag chain to the heatbed. If you remove some covers you can check the voltage and connection in each of these places.
Good luck!
Respondido : 05/10/2023 12:22 am
Dante
(@dante-3)
RE: No power at all
You are correct.  It was not the same issue.  This one was my bad.  I had the harness to the LCD reversed.  All good now and ready to go!
Thanks
Respondido : 05/10/2023 11:55 am
1 les gusta
Kdon
 Kdon
(@kdon)
RE: No power at all
When you say "If the light is on, the supply and fuse are fine." which light are you referring too? are the lights in the power buttons ( qty3) supposed to light up? I test all the fuses for continuity and only the main button lights up, the other two with the removable covers do not light up.
I had been using my printer with no problems for months. I turned it off and hadnt used it for maybe 2 weeks, went to turn it on today and nothing happened, only the main power button light would come on. inspected the PDU for connectivity and it appears fine, all connections intact, nothing loose per your experience.
Respondido : 20/09/2024 7:13 pm
JVIL
 JVIL
(@jvil)
Miembro
RE: No power at all
I haven't been able to get our Prusa X5 to pass the pin calibration test and have disassembled and reassembled most of the printer after 2 others put it together... I'm not going to bash anyone, but suffice it to say there were gaps and extra parts and wrong parts put in various odd places and the extruders were at a crazy angle. I finally got 3 of the tools to pass calibration today and then when the 4th failed, couldn't get the first to pass again with the screen blanking and shutting the printer off and back on with the same old error. I had noticed that the first time (the 3 passing) the calibration pin went into the hole and screwed down a lot further and since the heat bed is pretty much the only part (i think) that I hadn't redone, I took off the cover from the board underneath... I noticed that there is no fuse (no red #10 at all). I noticed that there are a few that have a ton of info on the fuses and electic schematics... am wondering if someone can please verify what we need to get to make the board right (I am putting the parts in the correct spots and actually put the screws that were missing in so the board is not bowed, but want to handle the fuse, if necessary, while the cover is off. Please provide any direction as I've searched and nothing I have found answers this specific question or even addresses the fuses. Also, If anyone has actual pictures and sizes of the screws, we'd love them as we've just got random screws and are missing many from the enclosure and had different screws on the mirrored areas and I'd like to make sure that the bed, especially near the heat bed board, screws are done correctly. Thanks so much in advance
for reference https://help.prusa3d.com/guide/how-to-fix-modular-bed-error-hw-solution_512077
Respondido : 07/10/2025 7:36 am
Your best chance of getting everything right is to contact Prusa support via the chat function.  You will need the serial number of the printer.
Respondido : 07/10/2025 7:03 pm
