1→5 tool upgrade: Filament Sensor Fail on one Tool Head
Greenhat
(@greenhat)
After doing the upgrade everything calibrated perfectly except for Tool 2 Filament Sensor.    It fails before asking to insert filament.   I checked that all connections are solid, no wires are pinched, etc.
I was waiting in line for Prusa support, but I need to go to work...  I'll try again tonight but wanted to check the hive mind for any other ideas.
Opublikowany : 23/02/2024 3:17 pm
RE: 1→5 tool upgrade: Filament Sensor Fail on one Tool Head
Is it the side filament sensor or the sensor in the toolhead? I had the side sensor 2 fail on me after the upgrade. I did hang in until I got someone from Prusa on the line,  he made me do a full reset of the firmware, which fixed the problem.
Opublikowany : 23/02/2024 7:45 pm
1 ludzie polubili
Greenhat
(@greenhat)
Nope.  Tool head.
Opublikowany : 24/02/2024 2:56 am
Greenhat
(@greenhat)
They work great!   You’re missing out by allowing the noisy few dictate your decisions for you.
Opublikowany : 24/02/2024 2:58 am
1 ludzie polubili
Brian
(@brian-12)
There is a little access hole right above the nextruder gears.  Try blowing some compressed air in there.  The ball may be stuck.
https://help.prusa3d.com/article/filament-sensor-mk4-mk3-9-xl_465702
Opublikowany : 24/02/2024 3:57 pm
1 ludzie polubili
Greenhat
(@greenhat)
doing a hard reset and reloading firmware seems to have fixed it.   All tests successful.
Opublikowany : 24/02/2024 8:32 pm
Guys,
can we please keep to the subject matter and the ethos of a support forum,
If a user comment upsets you, could you please move on,
If a comment or subject upsets you a lot, could you please report the post and let the moderators sort it out.
regard Joan
Opublikowany : 25/02/2024 9:21 am
3 ludzie polubili
